I purchased a stylus bar for my Columbia BK Lyric(which was originally missing), I had a new stylus replaced. I noticed that it seems to remove surface from my record, so I looked and it appears the metal edge is coming in contact with the record and slightly cutting (shaving) the record. I looked in Eric Reiss's book "Compleat Talking Machine", and it appears there are two stylus bars, The AZ and the Lyric and they are not quite the same.
I am thinking I may have a AZ installed instead of a Lyric, which may have more of a different angle.
Where can I get a stylus bar for a Columbia Lyric?
Columbia Lyric Stylus
Re: Columbia Lyric Stylus
Why don't you ask the supplier of the bar or the fitter of the new sapphire ?
- VintageTechnologies
I wonder if lengthening or shortening the link between stylus bar and diaphragm would change the angle so that metal does not contact the record? Pictures might help someone here make a diagnosis.
You have the right Lyric reproducer for your Columbia BK. I have a question: Are you playing black wax records? If so, that's one of the problems. These Columbia Lyric reproducers were designed for the 2 min Indestructible cylinders. The heavy spring on the reproducer applies pressure for loudness. They will destroy a wax cylinder. Also, check you see if the stylus is chipped. A way to tell is to lightly rub your finger nail on the stylus. If your finger nail is scratched, then the stylus is bad, and need to be replaced.
The stylus feels fine. My question is..... Is this the correct stylus bar? Is this the lyric or AT bar?
Would a BQ have the same reproducer as a BK? My BQ's reproducer has a smaller diameter spring than the one in your picture, and its sapphire is much longer (knob-on-a-stick looking) & points more downward than at the angle of yours.
- FloridaClay
It is most definitely the wrong bar, and easy to see why the one you have is doing damage to your cylinders. Here is my BK Lyric. Unfortunately, I don't have a source for the correct bar, inasmuch as I haven't had to replace one yet.
Clay
Clay
Hello,
I checked the reproducer on my Columbia BE ( same as BF just a smaller cabinet)and my stylus bar is just the same as yours. You have the correct stylus bar.I think that it is a linkage problem. Try a longer link. Hold the top of the reproducer in your hand and allow the weight to drop to its bottom position. Now check how the stylus sits. The tip of the stylus should sit proud of the stylus bar.
Pete
Pete
- FloridaClay
Pete, he has a BK, not a BE or a BF and trust me, unless Columbia used very different bars on BKs at different times, it is NOT the correct bar. The picture I posted is straight off a BK. The orientation of the ends of the bars where the stylus is mounted are completely different.flashpanblue wrote:Hello,
Pete
Clay
