It is currently Sun Feb 18, 2018 6:39 am
Post new topic Reply to topic  [ 8 posts ]
Author Message
 Post subject: Edison Sheraton Inlaid
PostPosted: Sun Sep 10, 2017 7:24 pm
Offline
I found a Sheraton Inlaid machine this weekend. Couldn't find a production date list on this model. I know it shows up in the 1919 Edison Catalog, but other than that I know nothing about when it was made. It's got a low serial number so I suspect not as many of this model were made.
Thanks in advance if anyone has any information.
Jim
Top
 Profile
 Post subject: Re: Edison Sheraton Inlaid
PostPosted: Mon Sep 11, 2017 1:12 am
Offline
Unfortunately, production date lists for Disc Phonographs are not available. Frow does mention that there were 300 SI-19 cabinets in stock as of Aug. 1922, but that the model was not profitable, and therefore not promoted. It was discontinued in Aug. 1927, with 238 cabinets in stock.
Top
 Profile
PostPosted: Mon Sep 11, 2017 10:47 am
Offline
This image of the data plate is such a tease. Why not some photos of the rest of the machine? ;)
Top
 Profile
PostPosted: Mon Sep 11, 2017 9:15 pm
Offline
Someone started to strip it, but I'm inclined to leave it alone at this point, it doesn't look too bad. It's noticeably larger than my S-19, by the way, and heavier.
Top
 Profile
PostPosted: Mon Sep 11, 2017 10:23 pm
Offline
That is a nice design: gives a little more class to the cabinet.
Top
 Profile
PostPosted: Tue Sep 12, 2017 3:05 pm
Offline
I wonder if we can assume these were the same cabinets from an original batch that remained in stock all those years?
Jim
Top
 Profile
PostPosted: Tue Sep 12, 2017 3:55 pm
Offline
Columbia78 wrote:
Jim
About 2 years ago I went to look at a B-275, which has a very similar appearance to the SI-19. That B-275 was a large machine, similar in size to a Chippendale. The OP's comment that his SI-19 was significantly lager than his S-19 tells me that the SI-19 was really a descendant of the the B-275, not a "sibling" of the S-19.
Interestingly, Frow used identical pictures in his book for the A/B-275 (p.120) and the SI-19 (p. 156). Based on the OP's pictures, Frow seems to have used pictures of the A/B-275 in both instances, as the inlay on the SI-19 appears to be a bit simpler than the inlay on the A/B-275.
Top
 Profile
PostPosted: Tue Sep 12, 2017 4:37 pm
Offline
The cabinet of this SI-19 looks identical to the A-275 except that the record storage compartment is a door not a drawer. My A-275 is dated October, 1913. This model may not have sold in great numbers but it was one of the longest running models available.
Roy
Top
 Profile
Who is online
Users browsing this forum: No registered users and 6 guests
Search for:
Jump to:
Americanized by Maël Soucaze.
