Just picked up this sweet little "untouched" Zonophone C.
It's nice to know that people are still pulling these out of the woodwork.
As my co-worker says, "Sometimes it's better to be Lucky, than good!".
I have had several C's in the past, but not this early version.
I like the petite little size of it!
I think it has Great Potential!
(In the last pic,I borrowed some parts from another of my machines, to show what it could be).
My advice: KEEP HUNTING! You never know what you might find!
Cheers, Bob S.
THEY ARE STILL OUT THERE!
- Zwebie
- CDBPDX
Re: THEY ARE STILL OUT THERE!
Lovely! Congratulations!
- alang
- VTLA
Congratulations! That is an awesome little machine. I love Zonophones. I guess finding the missing parts will be a challenge for such an early machine.
Good luck!
Good luck!
Nice find with great potential. Jerry B.
Beautiful little Type C, Bob! Congratulations!
Just an observation: the serial number, motor plate, and support arm placement would suggest that this isn't an especially early Zonophone.
Interesting cabinet. It's a miracle the celluloid plate has survived exposed that way!
- Django
Nice find. New England seems to be drying up. Not much left in the wild anyway. I'm glad there they still show up somewhere.
- Zwebie
George,Just an observation: the serial number, motor plate, and support arm placement would suggest that this isn't an especially early Zonophone.
Any Idea when this case was used for the "C" ???
Was it sold at the same time as the normal "C" case???
I have seen this case used on a very early Prescott tagged case with the flat bedplate, that's why I assumed it was early.
The Serial # of this machine is 6541
I just sold a normal cased "C" with the same bedplate, Serial #7049
And currently own a normal cased "C" with the same bedplate, Serial #8211
I also have a "B" with the same bedplate, Serial #8084
(As I understand it, this is the second style bedplate, with the under the bedplate spring loaded support arm)
Any help would be appreciated, Bob S.
Bob,Zwebie wrote: George,
I don't know when that cabinet was used for the C; I too have seen a couple of early Prescott-tagged Zonos with that cabinet design. Perhaps a few surfaced in inventory later on and were simply used alongside the conventional design? I just don't know.
That is indeed the second style motor plate, which again suggests slightly later production. Is there any possibility that the cabinet and works have not always been together? If found in the wild, I would assume they left the factory together.
- Zwebie
George,Is there any possibility that the cabinet and works have not always been together?
I can't say for certain that they had always been together, but when I unscrewed the bedplate to oil the motor, I had to bump the case because the bedplate was stuck to it. Also, all the oil in the motor was dried out and stuck. I'm thinking that it was the first time the case had been opened in 100yrs.
It may very well be the factory using up old cases, as you suggest, especially because of the location of the placement of the celluloid tag.
As always, the more we know, the less we really know.
Bob S.
- gramophone-georg
Bob- Really nice little machine!
