It is currently Thu Jul 19, 2018 3:50 am
Post new topic Reply to topic  [ 14 posts ]  Go to page 1, 2  Next
Author Message
 Post subject: Help with fitting a swollen reproducer
PostPosted: Wed Oct 11, 2017 1:57 pm
Offline
Finally got to go to my Godfathers house today and install the 2/4 min mech on his ICS machine. Looks and runs beautifully. When he purchased it the model C had swollen slightly in the carriage and couldn't pull it out...however it would wiggle. I put it in the freezer and it popped right out with a little push. I'm giving him a model H, but id like for him to be able to use his model C. I was thinking could I just use steel wool to remove a little on the sides of the body so it'll go in and out easily? Or is there another method?
His machine is drilled for cygnet crane so he purchased the mount and crane, and when my music master comes in tomorrow I'm gonna give him my extra cygnet horn. Gonna be a nice machine!
J.F.
Top
 Profile
 Post subject: Re: Help with fitting a swollen reproducer
PostPosted: Wed Oct 11, 2017 2:20 pm
Offline
Steel wool will never remove an amount of material that would help you. Very carefully filing the outer diameter of the reproducer body should help.
Top
 Profile
PostPosted: Wed Oct 11, 2017 2:35 pm
Offline
Hmm but making sure to keep it round seems difficult using a flat file. Would some fine sandpaper work? I can wrap it around and tug on each side and work my way around.
J.F.
Top
 Profile
PostPosted: Wed Oct 11, 2017 2:46 pm
Offline
I typically use emery paper (like sandpaper but designed for metal finishing) in this situation. You won't need much. Start with a fairly fine grit so as not to overdo it. Do a little, then check for fit, and repeat as necessary.
Top
 Profile
PostPosted: Wed Oct 11, 2017 3:33 pm
Offline
That's where the "carefully" part comes in. :) Besides, you only want to reduce the diameter by maybe .001/.002". How out-of-round can you get removing so little stock? Sanding may work, but will be very difficult to get into the corner, just under the flange, the way a file can do.
Top
 Profile
PostPosted: Wed Oct 11, 2017 5:00 pm
Offline
I have a set of finishing files from when I was custom building 1911s. I may try this tomorrow just to see. Shouldn't take much like you said. Maybe I could use a marker to see where high points are and go from there.
J.F.
Top
 Profile
PostPosted: Wed Oct 11, 2017 5:03 pm
Offline
I used a file on my swollen diamond B, it fits a treat now, you'll have success with a file.
Top
 Profile
PostPosted: Wed Oct 11, 2017 5:26 pm
Offline
Did you just lightly run it around the entire body? I'm guessing I may be able to find my fine file so as to not leave many scratches. Still unpacking from the move so I may just run down to Lowe's and pick myself up a small fine file to do this tomorrow.
J.F.
Top
 Profile
PostPosted: Wed Oct 11, 2017 6:06 pm
Offline
Personally I used quite a rough file at first and then finished with a fine file, I felt I had to remove quite a bit of material so it would fit smoothly, just keep doing it all around the reproducer and trying it in a reproducer carriage as not to remove too much metal. (your reproducer lies within the hands and experience of a 16 year old, GOOD LUCK!! :lol: )
Hope this helped, Jake
Top
 Profile
PostPosted: Wed Oct 11, 2017 6:10 pm
Offline
I'm Feeling Cranky
As a hint, I use my digital calipers to measure around the outside diameter, and note where the "high" spots are.
Best,
Fran
Top
 Profile
Who is online
Users browsing this forum: Bing [Bot], Vinrage_mania and 13 guests
Search for:
Jump to:
Americanized by Maël Soucaze.
