Has anyone ever seen a sapphire ball stylus with an odd shape like this to the shaft? It came with my Pathé VII. Most others are cyllinder shaped and not cut as this one. Any clues? Is this correct for a Pathé concert soundbox?
Thanks
Help identifying Sapphire Stylus
- pellicano1
Thomas A. Edison
Thomas A. Edison
Re: Help identifying Sapphire Stylus
Looks to me just like a regular Pathé stylus that someone filed half of its length. A Concert soundbox will take the fully cylindrical stylus (as this one probably was originally). This one might fit if the screw reaches to the filed surface.
- pellicano1
Ok I see the ridges now. Why on earth would someone do this?CarlosV wrote:Looks to me just like a regular Pathé stylus that someone filed half of its length. A Concert soundbox will take the fully cylindrical stylus (as this one probably was originally). This one might fit if the screw reaches to the filed surface.
Thomas A. Edison
Thomas A. Edison
- Lucius1958
Hard to understand, unless someone had a machine with a needle fragment (or something like that) partially obstructing the chuck...pellicano1 wrote:Ok I see the ridges now. Why on earth would someone do this?CarlosV wrote:Looks to me just like a regular Pathé stylus that someone filed half of its length. A Concert soundbox will take the fully cylindrical stylus (as this one probably was originally). This one might fit if the screw reaches to the filed surface.
- Orchorsol
To reduce volume?pellicano1 wrote:Why on earth would someone do this?
If they had a need to remove and replace the stylus, to ensure it was fitted in the same orientation each time?
- pellicano1
I inserted it into my Pathé Concert Reproducer and tried it on a Pathé disc. It sounds bad!Orchorsol wrote:To reduce volume?pellicano1 wrote:Why on earth would someone do this?
Thomas A. Edison
Thomas A. Edison
