Thank you to all the replies regarding Cygnet Horn painting. After completing the basic all black finish, I gold striped the outer seams and it looked pretty good. Then when I mounted the horn on the phonograph, the inside looked bland and unfinished, so I gold striped the inside seams and the horn "came to life". So, while I'm still not certain if the originals were striped on the inside or not, I definitely like the look when it is.
On another matter, I got the Cygnet No. 10 decals on eBay (came from Peru) and they have a gold background.
It appears from photos of original unrestored horns that the background is silver.
Am I missing something here?
Should they be silver? If so, does anyone have a source for the correct decal?
Again, thanks in advance
Cygnet Horn painting and Decals
Re: Cygnet Horn painting and Decals
Gregg Cline has the best decals around. Check his site.
http://phonodecal.com/decals/scripts/main1.php
- Phonolair
The original Edison Cygnet decal had a gold back ground.callron wrote:On another matter, I got the Cygnet No. 10 decals on eBay (came from Peru) and they have a gold background.
Larry Crandell
Phonolair wrote:The original Edison Cygnet decal had a gold back ground.callron wrote:On another matter, I got the Cygnet No. 10 decals on eBay (came from Peru) and they have a gold background.
Larry Crandell
The silver is what's left behind after the original gold toning has faded/worn away. The silver is there to give the original decal it's metallic looking shine.
- VictrolaGuy - Walt
Being someone who actually uses decals from both Gregg and Eduardo I can report from actual experience that both supply top notch products. While there is a lot of overlap in their offerings you will find that Eduardo produces some decals that Gregg does not, and vice versa. Both, therefore, are valuable resources.melvind wrote:Gregg Cline has the best decals around.
(As for those who prefer to "Buy American" you are in luck...Both guys are Americans.)
