Hi All -
I have run out of leather cord for the friction brake pad for Victor machines. I found some 5.0mm Solid Leather Cord that should work, but it is rather expensive. Anyone have a good source for this material?
TIA,
Mark
What are you using for Victor Brake Leather
- maginter
"The present is theirs; the future, for which I really worked, is mine."
Nikola Tesla
Nikola Tesla
- Auxetophone
Re: What are you using for Victor Brake Leather
Round sewing machine belt, otherwise you can get pieces from the usual parts sources (Ron, George, etc.)
- maginter
Perfect, thanks Brandon!HisMastersVoice wrote:Round sewing machine belt, otherwise you can pieces from the usual parts sources (Ron, George, etc.)
Nikola Tesla
Nikola Tesla
- Phono-Phan
I have tightly rolled the leather pulley belting and pressed it in the brake. It works great.
Ken
Ken
- Personal Text: Greg
I've actually used bits of an old belt. Not super elegant, but hey it works! If I had a bullet brake however, I'd purchase the actual thing as this solution isn't for looks
I bought a VV-XII at the last Sranton auction. It has a bullet brake and when I checked the machine out after bringing it home I discovered the brake leather was too short to contact the turntable edge. I pulled the leather out of the tube, wadded upa small piece of paper, shoved it into the tube then reinserted the leather. Works like a charm.
Jim
Jim
From a clock parts supplier. Scroll down and see various samples:
https://timesavers.com/search.html?q=leather&go=Search
- mattrx
Round sewing machine belt leather purchased from Amazon a few years ago. Have more than I will ever use.
Good Luck,
Matt
Good Luck,
Matt
- maginter
I am good for several years now. $2.99 shipped for a Sewing Machine belt 70 inches long from Amazon. Thanks for the input. Saved me about $15.mattrx wrote:Round sewing machine belt leather purchased from Amazon a few years ago. Have more than I will ever use.
Good Luck,
Matt
Mark
Nikola Tesla
Nikola Tesla
If you find that the diameter of the belt is a tad too big, just roll the piece you need between two hard boards and you can "squish" the diameter down enough to fit. Then, squeeze the ends of the leather with a plier to "re-expand" it. And, don't forget to soak it with a little oil when you're done. That will help it last a long time.maginter wrote:I am good for several years now. $2.99 shipped for a Sewing Machine belt 70 inches long from Amazon. Thanks for the input. Saved me about $15.mattrx wrote:Round sewing machine belt leather purchased from Amazon a few years ago. Have more than I will ever use.
Good Luck,
Matt
Mark
