Travis,travisgreyfox wrote:Thanks for all of the advice. I took the spring out of the bottom one (in the pic) and cleaned and re-greased already. I guess I will do the same for the other two.
Is there a possibility that the spring on the left (in the pic) is stretched out and not winding because of it? If you look closely it looks different than the rest, it looks as if the inner end is bigger and may need to be pinched in like the rest? I'm just speculating as I have never done any motor that has more than 2 springs before.
Thanks,
Travis
A worn out, "stretched out", spring will not cause the motor to wind forever. Let us know what you find when you get the other two out.
