Another newbie question
I was able to get my machine open tonight and took the attached video of its mechanism. How far off is this from normal and is it common with a basic fix?
- trim.270D39C7-E47D-40DB-8262-846C4EE5740D.MOV
- (10.37 MiB) Downloaded 776 times
Re: Another newbie question
Your motor is gunked up with decades of accumulated grease and oil and is binding frequently. Based on what looks like a start-and-stop problem, there may also be bearings that are too tight and are preventing the mechanism from running smoothly. I would recommend a complete disassembly, grease and oil removal, and reassembly with modern lubricants. At that point you can also adjust the bearings so that everything rotates properly.
Great, thank you. I will aim towards doing that.
semi-related question - I am a little wary when cranking this up because I don't know how far I would go before I over-wind it? Is there an accepted number of rotations, or will I be able to feel when it's fully cranked?
Yes, you will learn the feel as the spring approaches a full winding. But I'd wait until your motor has be degreased and serviced before giving it a good winding.
Jerry Blais
Jerry Blais
...and if you do decide to do the work yourself, be sure to let the motor run down completely so that there's no tension at all in the springs before you start taking things apart.
- Phono-Phan
The arm that runs against the governor and moves the speed indicator needs to pivot freely. I have had these bind up and really affect the operation of the motor.
