I would appreciate a discussion on the identification of 10" cone horns. Is there a difference between Columbias and Edisons? Are both crimped and soldered small ends correct? Is the length of the crimped end significant? Is there an easy way to differentiate between original and reproduction? Thanks for your comments.
Thanks, Jerry Blais
(I did use the "search" feature but didn't find much. Maybe I need a lesson! )
How about a discussion on 10" cone horns?
Re: How about a discussion on 10" cone horns?
How embarrassing, I even replied! Jerry BlaisGreat topic! Thanks George for your reply. I always had believed only the reproduction cone horns had soldered small ends. I learned something today. Jerry Blais
What is the best way to use the search feature on the Forum? Jerry
The forum search feature doesn't like "little" words (up to 3 characters) so it ignores them. The best way to search the forum is actually to use google or other search engine. The syntax looks like this:Jerry B. wrote:What is the best way to use the search feature on the Forum? Jerry
site:forum.talkingmachine.info 10 inch cone horn
If you search like that, all the posts with those last 4 words in them anywhere will come up. If you want to search for an exact phrase, put it in quotes:
site:forum.talkingmachine.info "10 inch cone horn"
- Polyphone
- Personal Text: There is a fine line between clever and stupid
Hey folks, here is another variation of the 10" conical horn with an extended soldered tube.
Best, Ken
Best, Ken
Jerry, You were the one to show me how to use the Forum features when I first started out. I asked you how to search for things and you told me to type in the keywords and the topic would show up. I've been doing that ever since. Good luck with the search.
52089 wrote:The forum search feature doesn't like "little" words (up to 3 characters) so it ignores them. The best way to search the forum is actually to use google or other search engine. The syntax looks like this:Jerry B. wrote:What is the best way to use the search feature on the Forum? Jerry
I was going through my Columbia machines and have the AQ model. The end of this horn has the crimped end, not the soldered tube. Is the the exception to the rule? That's the same as my AQ Harvard Jr. Also with the crimped end on the B & B horn.
- ehs004
After talking to Jerry this morning about 10" cone or conical horns as they are being referred
to i thought i would share a few more pictures of original small horns .Thanks for the call Jerry !! I would like to add that i bought a Model B Gem with the horn it was sold with from a granddaughter of the original owner and it was seamed and i bought a Model B Eagle from the same and it came with the soldered nipple pictured in middle
Eric
Eric
