Help!....ID this horn
Vinrage_mania
Post by Vinrage_mania »
I picked up a few horns ....with the dreded ictrola XO parts and want to try and figure out what it is for .The small end is 1 ½ and the bell is 8 inches the adapter goes down to ⅞ inch any ideas?? Thanks !
Here is a better photo of the bell it has a gold strip at. The edge
Roaring20s
Re: Help!....ID this horn
Post by Roaring20s »
Ripduf1
Post by Ripduf1 »
Hi, Please post a picture of a side view to be sure.
But to my eye it appears to be a common Columbia black horn. The brass end is different and I cannot ID it except that it appears to have the Columbia set screw on it, so it maybe a common horn with a not often seen adapter for a phono rather than a disk machine (Columbia Elbow). I will leave that to the Columbia collectors to hash out.
Please post a side view picture and length with out the brass bit. That will help ID it correctly.
John
Horns rolled and straightened
Vinrage_mania
Length is 13.75 ish....with out the adaptor witch has very small barbs on the inside
Side view
Side view
Post by Phonofreak »
This appears to be the all black Columbia horn. If the length is 14" with an 8" diameter bell, then it is definitely a Columbia one. The brass fitting is probably an aftermarket adapter for use as a cylinder horn.
ehs004
Post by ehs004 »
Vinrage_mania,
If James is right about the adapter i would be interested!
Thanks Eric
