Hi Folks -
As I mentioned in a previous post, the grand-daughter of my great uncle inherited his collection of phonographs. His stuff all got boxed up quickly after he died in the early 1990s and it's been sitting in her attic since. I'm in the process of converting all my grandparents' and great-uncles' home movies and after contacting her to inquire about the home movies he shot (which go back to the '20s), we got together. I think after assessing me as a history and mechanically minded person, she mentioned his other stuff mainly the phonographs and offered me the Amberola 75 as a kind of "thank you" for taking on the home movie preservation. She's very interested in seeing the movies as well.
In any case, while I was getting the Amberola out of the attic I took a few pictures of some of the other phonograph pieces and parts. As I educate myself on these, I think some of it might be of some value. This is all her stuff, I have no access to it, although I am keeping a close eye on it. She lives only a few minutes from me.
Without further ado...
Additional machines in the house of the Attic Amberola
- Personal Text: It plays a what now?
Re: Additional machines in the house of the Attic Amberola
Hi Folks -
I'm not sure how many photos you can add to a single post so I'm continuing here.
This machine is set up in her living room. I think this is where we have "the good stuff".
Bryan
Bryan
- Chuck
WOW!!! That poor Edison Home Phonograph!
I bet the guide rod for the carriage arm is
flexing in an upward direction with all of that
overhung weight.
Not to mention the severe force on the
reproducer neck....
When I see stuff like this, it really amazes me,
and not in a good way...
Yes, by all means, Jerry is correct in his post
below that the first order of business next time
you get over there is to get that heavy horn
off of that Home machine ASAP. Hopefully the machine
is not too damaged.
overhung weight.
reproducer neck....
is not too damaged.
-Bell System Credo
-Bell System Credo
You show some nice things in your photos. In addition to a couple of nice horns you see some Victor horn machine parts such as the slotted crank and the back bracket and tone arm assembly. Plus there's the top works for an Edison Standard.
Yes, that appears to be much too large a horn to be supported entirely by the reproducer on the Home. The photo shows the reproducer already about half way out of the carriage. I would strongly suggest that the horn be removed immediately. I'll bet there is a horn crane somewhere in the attic. Look for some metal rods and assorted small parts. If unsuccessful, Ron Sitko sells a nice replacement for about $75. Look in the links section of our Forum for contact information. If left as is, you run the risk of breaking the neck on the reproducer or the reproducer is pulled out of the carriage and damage to the horn from the resulting fall.
The Home is a Model B which left the factory as a two minute player. When four minute cylinders were introduced in 1908 Edison made parts available to convert all prior machines into combination 2&4 minute players. The Home was converted. Also, approximately the first third of the B Homes had the desirable banner decal.
The record cabinet could well be the prize of the collection. It is spectacular.
So your next assignment is to take care of that Home. Please separate the horn from the reproducer. If the horn feels stuck to the reproducer, support the horn and back off the knurled screw that holds the reproducer and remove the reproducer with the horn. If the reproducer is stuck in the carriage please report back for additional suggestions.
Best wishes, Jerry Blais
- fran604g
Very nice! Good luck with everything.
Best,
Fran
Best,
Fran
- Lucius1958
The Standard works could be from a Model A or B. The cloth obscures where the speed control would be on an A: but I'm guessing it's a B with the internal speed control.
The (Herzog?) full barrel cylinder cabinet is an absolute wonder!
And, yes, get a crane for that Home posthaste: the only horn that doesn't need a crane is the small 14" "witches' hat" type.
Could that wood box that the standard part is in be part of the Victrola that that horn and tone arm will attach to. ??/ Tom
I don't think so. Victor horn cabinets are square not rectangular. It would be fun to have a look in that attic. Jerry B.Could that wood box that the standard part is in be part of the Victrola that that horn and tone arm will attach to. ??/ Tom
That round record cabinet is a VERY desirable item. Tell her not to let anybody talk her out of it without knowing more about it.
- EdisonWizard
Absolutely! I would love to get that cabinet!! Perfect for my opera.JerryVan wrote:That round record cabinet is a VERY desirable item. Tell her not to let anybody talk her out of it without knowing more about it.
J.F.
