Hello,
I recently bought these two phonographs and am in need of some parts. The Standard Model E needs a new main spring and I guess there is a rubber part in the reproducer that needs to be replaced. The BZH is in need of a new fiber washer on the bevel pinion (I think that is what it is called) The last picture shows what I am looking for. Also, should that part move up and down at all? It moves about a quarter inch or so?
Columbia BZH and Standard Model E
Re: Columbia BZH and Standard Model E
I believe everything you need is available from Ron Sitko and his contact info is found in the Links section of our Forum. Jerry B.
