Edison C-250 Fixed Up
Jwb88
Post by Jwb88 »
Finally posting these. I've always wanted a nice C-250 and I finally got one from Mike Sorter's garage. Just took a little work.
this is a fairly early one so I'm still piecing it together to what I think it had originally. How I received it was with a mechanism from the late teens in it with the automatic electric stop, which is cool, but I think it would have originally had the bedplate with decals, etc. It's working fine and it's the reason I bought so many diamond discs yesterday.
Someone drilled a hole in the back of it and while I probably should have re-veneered the whole panel, two things: 1) this is a long-term keeper for myself and so I'm the only one I have to please and 2) IT'S THE BACK so...I filled the hole and patched it with a little circle of mahogany. I'm fine with it.
I went through some work JB welding a mute ball assembly together only to find out that it sounds so much better without it that I think I'm going to remove it again. A little loud, but other than that it's great!
BEFORE:
Jwb88
Re: Edison C-250 Fixed Up
Post by Jwb88 »
DURING:
Jwb88
Post by Jwb88 »
NOW:
This is very hard to photograph. Some views it's pretty vivid red. Mostly it's glare, lol.
Jwb88
Post by Jwb88 »
First time removing backgrounds. Nice or weird?
Here's what the back looks like. You can see a ring in high light if you look closely but in general room lighting it's pretty undetectable. To me, anyway. AND IT'S THE BACK.
Here's a shot in progress showing how red it is in the light (and before a final French polish of shellac, so that probably darkened it slightly)
gramophone-georg
Post by gramophone-georg »
:shock:
Vinrage_mania
Post by Vinrage_mania »
Very Nice! :)
Valecnik
Post by Valecnik »
Beautiful workmanship! You did a really great job, including fixing that hole in the back. I think you were better off patching than re-veneering, especially on the backside.
Congrats on bringing back a beautiful machine from the grave!
billybob62
Post by billybob62 »
Outstanding!!
Roaring20s
Post by Roaring20s »
You should be very proud of the overall job and that hole fill especially. I certainly would!
James.
Pete Stratford
Post by Pete Stratford »
What an amazing job! I can hardly believe that it is the same machine. Well done!!
