Spring barrel Spinning
ts_13
Post by ts_13 »
Ok.... I picked up a little VV-VI cheap. It winds up if I hold the spring barrel, but if I let it go the barrel spins fast. What am I missing?
T
Re: Spring barrel Spinning
Post by soundgen »
Trashed spindle gear ? post pictures how else do you expect a diagnosis ? Spiritualism ?
ts_13
Post by ts_13 »
soundgen wrote:Trashed spindle gear ? post pictures how else do you expect a diagnosis ? Spiritualism ?
Didnt take spiritualism. Springs are bad.
CDBPDX
Personal Text: A Hobbyist Specializing in Sales and Repair of Spring Motor Phonographs
Post by CDBPDX »
Your VI has a 2 spring motor, it is likely that one spring is broken and one is not. The unbroken spring winds OK when you hold it but when you include the broken spring, it just spins.
The spring that engages the winding gear is good, the play gear spring is bad.
Cliff
ts_13
Post by ts_13 »
CDBPDX wrote:Your VI has a 2 spring motor, it is likely that one spring is broken and one is not. The unbroken spring winds OK when you hold it but when you include the broken spring, it just spins.
Cliff
Bingo!!!!
I just had my first bout with a spring. It had come lose (separated) from the barrel. I took it apart attached it to the barrel and re wound it. IT works!!!
Thanks!
T
