SINGLE PIECE CYGNET HORN SUPPORT (Bracket)
Was wondering if this single piece cygnet horn bracket is original or not? Was found on an Edison Triumph Model B which had been updated with a 2/4 minute combination attachment along with a Model O Reproducer. Have included photos. Any thoughts or comments would be appreciated.
Re: SINGLE PIECE CYGNET HORN SUPPORT (Bracket)
I do not believe it is original. The spring support assembly is definitely not from the Edison factory. My two cents worth.
Dave D
Dave D
- Phono-Phan
Definitely homemade.
I have a somewhat similar piece that came to me with a Standard. I think George P said he thought it might have been a staircase rail bent to shape. You can add me to the "home made" vote.
Thanks to all those for their responses. I appreciate it. I had a felling that it may be reproduction, but wasn’t 100% certain. So the only Cygnet Horn Supports made for Edison machines were nickel-plated steel, two-piece ones?
I wouldn't say reproduction so much as home made during the time period of phonographs.
Yes. The earliest top rods are of a flatter design and use a rigid mount to suspend the horn. The cygnet crane bottoms of Firesides, Standards, and Homes are the same (with two variations in step-back depending on the type of carriage being used).nosforless wrote: So the only Cygnet Horn Supports made for Edison machines were nickel-plated steel, two-piece ones?
The Triumph/Idelia/Alva cygnet crane bottoms are a couple of inches longer than the others, and are difficult to find. This probably explains the crane you picture. Someone needed a cygnet crane for a Triumph, and couldn't find an original. However, they clearly had access to a Fireside/Standard/Home cygnet crane to copy (they didn't do a bad job).
