SOLVED!! HELP with Victor Orthophonic Brass Reproducer
- pellicano1
Hey all. Someone had done a horrible black paint job on the back flange of my brass orthophonic reproducer. I stripped it off to reveal all brass as shown in photo. Was wondering if there are any tips you can provide for painting to original black. My concern is the paint causing the fine embossing to be hidden. Also, should primer coat be done before the black? I was going to leave it as it is but I would like it to look more original! I also plan on getting the front plate re-plated. Thanks all!
Thomas A. Edison
Thomas A. Edison
Re: HELP with Victor Orthophonic Brass Reproducer
I would just mask off the rest of the reproducer and spray on a thin coat of flat, or semi-gloss, black. As for the gold, it looks very nice as-is, and better than most. I would leave it alone, ESPECIALLY if the reproducer sounds good as-is and does not need rebuilding. Chances of getting an authentic looking gold finish are slim.
I would use Birchwood Casey Super Gun Blue. It is very dark, almost black. Make sure the surface is clean. Apply with a Q tip. Because this is a chemical application, the fine details will not be obliterated. Most Victor Brass reproducer have a dark black/blue finish anyway. The potmetal ones are painted black.
- pellicano1
Thanks!!JerryVan wrote:I would just mask off the rest of the reproducer and spray on a thin coat of flat, or semi-gloss, black. As for the gold, it looks very nice as-is, and better than most. I would leave it alone, ESPECIALLY if the reproducer sounds good as-is and does not need rebuilding. Chances of getting an authentic looking gold finish are slim.
Thomas A. Edison
Thomas A. Edison
- pellicano1
Thanks!! Will give this a go!Phonofreak wrote:I would use Birchwood Casey Super Gun Blue. It is very dark, almost black. Make sure the surface is clean. Apply with a Q tip. Because this is a chemical application, the fine details will not be obliterated. Most Victor Brass reproducer have a dark black/blue finish anyway. The potmetal ones are painted black.
Thomas A. Edison
Thomas A. Edison
- pellicano1
Touched up the reproducer. Now awaiting Birchwood Casey Super Gun Blue shipmenmt.
Thanks again all!
Thanks again all!
Thomas A. Edison
Thomas A. Edison
- Retrograde
Why use gun blue when there's brass black available?
- pellicano1
Birchwood Casey Super Gun Blue failed miserably. I believe it's because it works in steel and not brass. Any other suggestions? Do they sell a paint specifically for brass??
Thomas A. Edison
Thomas A. Edison
- Retrograde
You may have missed my post above your's. Is THIS not what you are looking for? it's all over eBay for about 8 or 9 bucks.
I have used Birchwood Casey for years on brass. The brass needs to be super clean. Any bit of dirt or crud will not make it work.
pellicano1 wrote:Birchwood Casey Super Gun Blue failed miserably. I believe it's because it works in steel and not brass. Any other suggestions? Do they sell a paint specifically for brass??
