Sorting through records this weekend, I noticed that my Grand Prize labels were somewhat thicker than the patent and batwing labels, and even my one Monarch label record, recorded in '03 and probably produced in '04.
I know having just one of these doesn't make it a really reliable comparison, but the patents and batwing are consistently less thick. Was there a difference in composition, or just a change in the amount of material?
Victor Record Thickness
- Victor A
- Personal Text: "Are you suggesting coconuts migrate?" - Graham Chapman
SOUSA, The March King, says:
- Wolfe
Re: Victor Record Thickness
They probably used whatever amount that was needed to set up properly in the record presses in the pressing plant. Composition of shellac unlikely to be causing the difference.
- Victor A
Ah, I see. Thanks for the information.
I found that the pre-Dog Monarchs in the 3000 series are thicker than the later Patents and Wing label Victors.edisonplayer
- Victor A
Mine is in the later 2000 series (2614), so I wonder if that might tell us about when they switched to different pressing machines.
