It is currently Mon Mar 25, 2019 7:56 pm
Post new topic Reply to topic  [ 13 posts ]  Go to page 1, 2  Next
Author Message
 Post subject: Suggestions for Exhibition Needle Bar Repair Please!
PostPosted: Sun Jan 21, 2018 7:12 pm
Offline
Stop for a visit when in Oregon.
This is the Exhibition that came with the little Victor 1 that I recently restored. As you can see, the needle bar is only partially there. I'd like to repair the sound box and keep it with the Victor 1. Any suggestions?
Thanks, Jerry Blais
Top
 Profile
 Post subject: Re: Suggestions for Exhibition Needle Bar Repair Please!
PostPosted: Sun Jan 21, 2018 7:30 pm
Offline
Jerry,
You could unsolder the broken piece from the base and replace it with another. That is if you have another one from a needle bar with other damage.
Bob
Top
 Profile
PostPosted: Mon Jan 22, 2018 9:46 am
Offline
Auxetophone
TMF Administrator
The easiest and most obvious fix would be to locate a replacement needle bar from one of our trusty parts sources. That's what I would do.
Brandon
Top
 Profile
PostPosted: Mon Jan 22, 2018 12:54 pm
Offline
VTLA
TMF Moderator
Looking at the adjustment screws and knurled nuts I think this may be a round hole needle bar for which no replacements are available. Therefore I would tend towards trying to repair it, meaning replacing just the broken part. Unfortunately that may require to sacrifice a later needle bar or new reproduction part. I know from experience that the upper needle bar piece can be removed/unsoldered relatively easily.
Good luck!
Top
 Profile
PostPosted: Mon Jan 22, 2018 2:05 pm
Offline
Yes, it's a round hole Exhibition that came with the Victor 1. I hope to repair it and keep it with the machine. Years ago I bought a replacement needle bar and assembly from Bob Fulwider (SP? - yes that was a loooong time ago) and it didn't look anything like an original. Are the replacement needle bars from Ron Sitko or Musical Americana similar to originals? Thanks, Jerry
Top
 Profile
PostPosted: Mon Jan 22, 2018 2:29 pm
Offline
Auxetophone
TMF Administrator
I was more referring to a replacement rather than a reproduction. I didn't even realize new ones were being produced. I know George V. usually has some original ones on hand, and I've also bought partial/parts reproducers on eBay for such parts in the past. If I had the skill to repair one, perhaps I would. But I don't :lol:
Brandon
Top
 Profile
PostPosted: Mon Jan 22, 2018 3:08 pm
Offline
VTLA
TMF Moderator
I put a Ron Sitko replacement with the triangle hole on one of my Exhibition reproducers and have to look very closely to find it again. Biggest difference are the adjustment screws and nuts I think. Ron only sells the whole assembly, which for $25 isn't a bad deal I think.
Top
 Profile
PostPosted: Mon Jan 22, 2018 6:39 pm
Offline
I trust that needle thumbscrew is free, if not I would have already commenced with the penetrating oil.... :) Bill K
Top
 Profile
PostPosted: Wed Jan 24, 2018 6:38 pm
Offline
Jerry, I would get a replacement needle bar from one of the dealers. Then I would send the reproducer to one of our reproducer re-building experts. Then I would have them graft the upper portion of the reproduction needle bar to the original bottom. I have done this before. It is straight forward, and a bit tedious to get everything aligned. To get it right, it is about a three hour job, but worth it to save the needle bar.
Top
 Profile
PostPosted: Sat Feb 03, 2018 9:29 am
Offline
The bar is soldered into the base plate. I could repair this if you want to send it.
Ken Brekke
Top
 Profile
Who is online
Users browsing this forum: No registered users and 6 guests
Search for:
Jump to:
Americanized by Maël Soucaze.
