Phonofreak wrote:
Make sure the crud, rust, residue is removed. I use spray cleaner. After it is cleaned, I use Krylon glass black Fusion paint. You don't need primer for this. It gives a very tough, hard finish. It is practically a dead ringer of the original color. On a side note, this is great for bed plates and black horns. If the finish is too shiny, you can dull it down with 0000 steel wool. Always use multiple thin coats. Let each coat dry and cure for 24 hours. Once you get the desired finish, get a set of Greg Cline decals. Follow the easy directions. Then coat with Bulls-eye orange shellac, to get the desired aged look.
Did you mean krylon GLOSS black fusion paint?
Does it say for plastic on the can?
Thanks,
Stephen
