A pig in a poke, but pretty neat:
http://akroncanton.craigslist.org/clt/990912323.html
New-In-Crate Edison S-19 in Ohio! Craigslist find.
- coyote
Re: New-In-Crate Edison S-19 in Ohio! Craigslist find.
I should check that one out...IF the weather and my schedule would permit a 2.5 hour drive for the fun of it. Hm...wonder if that would fit in the back of my car. I've fit a C-250 in there before...
- Covah
- Amberola 1-A
Is it me, or does that crate look like it sat in standing water for a period of time? Lot of warping on the bottom of that crate.
Check with your dealer for the latest Edison Records!
I would consider buying it if i were able to observe it first(the crate i mean) I would even see if he would let me use one of the scopes doctors use to look down your nose I would find a crack in the crate and use it to look around on the inside.Regardless of condition i would end up buying it...I just like these sort of things...
Aaron
Aaron
- AZ*
Excellent observation. I ran across some crated Victrolas about 15 years ago that had been stored in a leaky barn. Although they had never been uncrated, they were in poorer condition than the typical machine that had seen 80 years of use.Amberola 1-A wrote:Is it me, or does that crate look like it sat in standing water for a period of time? Lot of warping on the bottom of that crate.
Looks like a "grab bag" to me.
Best regards ... AZ*
- solophoneman
Like buying a grab bag!! You just never know where this crate was stored over the years, it could have been in a damp or wet basement that was flooded at one time or another. Look at the bottom section of the crate, it appears to be a bit darker then the top. Was it sitting in a flooded basement or storage area? There could be severe moisture or water damage to that machine, despite the fact that they claim it has never been uncrated. Also can you imagine new old stock staying in a crate for 80+ years and no family member or anyone else curious enough to open it up and want to see what was inside ? It boggles the mind!!
So this is where Jimmy Hoffa really ended up!!
Yeah, look at the 1957 Plymouth from Tulsa, OK! Brand new...but in worse shape than most on the road today! What a shame! http://www.tulsaworld.com/webextra/cont ... fault.aspx
- solophoneman
Yes this could completely blow the theory that he was dumped into a rotating pugmill at a local Asphalt Batch mixing Plant and was ground up along sand & stone and liquid asphalt into a batch of hot Bituminous Concrete which was later spread as pavement on some local Roadway or Highway, with thousands of motorists later driving over Jimmy's cremains and never realizing it !!schweg wrote:So this is where Jimmy Hoffa really ended up!!
