WANTED: Motor for early Columbia AH
I have just about everything I need for my Columbia AH project except for the motor. At this point I'll accept parts for the motor and build it from that. Any help is appreciated! It is the early model with the offset crank and speed control on the motor board. Also needed is the spring loaded lid latch.
Re: WANTED: Motor for early Columbia AH
There are several types of motors for the Columbia AH. The earliest ones had an off center crank with a metal bedplate. The second one had the center crank, but with a vertical governor. The third and most common one, had the center crank, and horizontal 2 ball governor.
Yes, it is the off center one with the metal motor bedplate.
