Wanted: Meltrope 1 or Micro Perophone sound box
sigurbjorn
Post by sigurbjorn »
Hi
I need to find Meltrope 1 or Micro Perophone sound box new or good used for my Micro Perophone Chromogram.
CharliePhono
Personal Text: "The kerosene record player is not a very efficient device." ~Frank Zappa
Re: Wanted: Meltrope 1 or Micro Perophone sound box
Post by CharliePhono »
Hello. Do a search on ebay.co.uk. I saw two listed there today, one with a current bid of £30. The other had a start bid of £1, but with astronomically high shipping (I suspect as much because the seller fears it might actually sell for a pittance and would make up the difference on shipping).
CharliePhono wrote:Hello. Do a search on ebay.co.uk. I saw two listed there today, one with a current bid of £30. The other had a start bid of £1, but with astronomically high shipping (I suspect as much because the seller fears it might actually sell for a pittance and would make up the difference on shipping).
Here is the link to the Meltrope 1. http://www.ebay.co.uk/itm/142318907768
It is located in Germany, so I cannot say whether or not the postage charge to Iceland is reasonable.
Roger.
The Meltrope III is an excellent performer. The main reason why I chose a Meltrope I for my Chromogram was appearance, as it is nickel plated whereas most Meltrope III's have a bronze finish. Either soundbox in good condition will transform the performance of your machine, although it already sounds pretty good to me.
Roger.
sigurbjorn
Ok guys, thanks
sigurbjorn
Still looking
sigurbjorn
The performance of my Chromogram was transformed by a Meltrope I, but the rubber coupling on this one looks tired and non-original. It should be red not black. Replacements in various sizes are available. Choose one with the correct internal diameter for your tonearm and all should be well.
I believe that forum member Chunny has had these couplings re-manufactured and has listed them on UK eBay. If there are none listed at present you could send him a PM.
sigurbjorn
epigramophone wrote:The performance of my Chromogram was transformed by a Meltrope I, but the rubber coupling on this one looks tired and non-original. It should be red not black. Replacements in various sizes are available. Choose one with the correct internal diameter for your tonearm and all should be well.
Ok many thanks.Then I will keep looking
