It is currently Tue Oct 16, 2018 6:24 am
Forum rules
Please click here to view the forum rules
Post new topic Reply to topic  [ 11 posts ]  Go to page 1, 2  Next
Author Message
 Post subject: Wanted : Mandrel and Shaft for Edison Standard Model C
PostPosted: Thu Nov 09, 2017 7:34 pm
Offline
Don't need the gear or pulley.
Larry
Top
 Profile
 Post subject: Re: Wanted : Mandrel and Shaft for Edison Standard Model C
PostPosted: Thu Nov 09, 2017 7:53 pm
Offline
Hey Larry, won't a mandrel and shaft from a model D fit? The only difference is the 2/4 min. gearing will be off.
Top
 Profile
PostPosted: Thu Nov 09, 2017 8:01 pm
Offline
You might be right. Anyone know for sure?
Larry
Top
 Profile
PostPosted: Thu Nov 09, 2017 8:33 pm
Offline
Skilled Craftsman produce radio cabinets at RCA Victor in Camden, N.J.
The C shaft is physically different in appearance, with a "nose" on the left side.
The second gear is different too, as I recall. nad not sure of the bedplate hole locations for the second gear.....
Hope this helps, Bob
Top
 Profile
PostPosted: Fri Nov 10, 2017 1:37 am
Offline
I believe a mandrel and shaft will work in the C from a model D out along with the pulley. As said above it did have a different front on the original shaft though. It takes the small gear from a model B in the front. It takes a different second gear and worm screw. that are somewhat unique to a model C. It will also take a complete set of gears and mandrel from a model D out and you will have a model C with the model D gears. That is not how it comes from the factory though. All the holes are drilled into the bedplate to be a C or a D. That was how all future bedplates were configured out to the model F from the Edison factory. Tom B
Top
 Profile
PostPosted: Sat Nov 11, 2017 10:50 pm
Offline
hey larry,
the d mandrel will not work on the c at all as the the c has a different shaft hole on the left end and a different style mandrel bearing....it is a tough mandrel to find as no other style like that was used on any other standard model phonograph.
hope this helps,
mark
Top
 Profile
PostPosted: Sun Nov 12, 2017 2:41 am
Offline
mark gaisser wrote:
hey larry,
hope this helps,
mark
Mark is probably right but I am now interested and Tue or Wed I will tear apart a C and a D mandrel machines and see if they cross. The main point would be the bearing. Tom B
Top
 Profile
PostPosted: Sun Nov 12, 2017 3:48 am
Offline
Do you need a shaft or mandrel, i.e. what is bad on yours or is the mandrel and shaft completely missing?
Top
 Profile
PostPosted: Sun Nov 12, 2017 12:05 pm
Offline
I need both. The shaft I think is bent and mandrel slides up and down.
Larry
Top
 Profile
PostPosted: Tue Nov 14, 2017 5:10 pm
Offline
I took the mandrel off a model D and ran it on my model C. It will work with a adjustment or part change. The mandrels are basically the same height with the C mandrel being about ⅛ inch taller than the D mandrel. The small end gear from the model C will not work on the D mandrel as it has a bushing in it so you will need a model A or B end gear. The end bearing worked for both. As long as you have the second gear and the worm screw from the model C ( as they are unique to the C ) you will be ok till you can find a replacement for the mandrel and end gear to bring it back to original. The C mandrel has the small end and is tapered on the shaft till it gets to the correct pulley diameter. The D mandrel will work on the C pulley. I hope this helps you but there is a fairly large extra expense made till you can replace the D parts with the C parts so take that into consideration. The D mandrel is readily available. Here are some pictures. Tom B
File comment: Bearings are close...
File comment: different end lengths but heights close
File comment: two mandrels C has the rounded end
File comment: It works
File comment: Flat end shaft
File comment: You can see the bushing in the pulley
Top
 Profile
Who is online
Users browsing this forum: Google [Bot] and 7 guests
Search for:
Jump to:
Americanized by Maël Soucaze.
