Just brought home a nice Victrola VV-XVI serial number 72289E with no motor. Anybody have a spare 3 spring with double cut spindle? OK if it is broken as long as the parts are all there.
Thanks!
Cliff
WANTED: Early 3 Spring Victrola Motor c.1913
- CDBPDX
Re: WANTED: Early 3 Spring Victrola Motor c.1913
Could someone post a photo of the motor that goes in this Victrola? Is it the same as an "L" door? Thanks, Jerry
- Personal Text: Greg
It is my belief that this Victrola uses a variation of the L-door motor, with direct wind. The two are incompatible, and this motor was also used on the 1913 XIV. I could totally be mistaken, but I'm fairly confident in this fact. This is a sold eBay listing of what you'll need. The standard L-door motor has gearing in place to move the crank.
https://www.ebay.com/itm/VICTOR-VV-XVI- ... 2047675.l2
- mattrx
GregVTLA wrote:It is my belief that this Victrola uses a variation of the L-door motor, with direct wind. The two are incompatible, and this motor was also used on the 1913 XIV. I could totally be mistaken, but I'm fairly confident in this fact. This is a sold eBay listing of what you'll need. The standard L-door motor has gearing in place to move the crank.
I think he is right. I once owned an extra of this style motor and traded it off because I couldn’t find s machine for it. Direct wind, cranks on the opposite side of the l-door version, and the speed control is in the rear.
Matt
Hi Matt,
Didn't you give me a motor like this? Cliff is a good fellow. If it's the motor he needs I will just pass it off to him.
Thanks, Jerry
Thanks, Jerry
Here's the picture...GregVTLA wrote:It is my belief that this Victrola uses a variation of the L-door motor, with direct wind. The two are incompatible, and this motor was also used on the 1913 XIV. I could totally be mistaken, but I'm fairly confident in this fact. This is a sold eBay listing of what you'll need. The standard L-door motor has gearing in place to move the crank.
Thanks for posting that picture, it'll preserve the usefulness of this topic long after the eBay listing is gone
- CDBPDX
The Victrola book says this version 'E' has almost the same motor as the last L-door with 3 springs, double cut spindle, a 5/16" female winding crank, indirect winding. The motor for the last L-door is described the same except the winding crank is ¼" instead of 5/16".
Though the motor on Ebay had a quad cut spindle, it might still have worked.
Looking forward to seeing your motor, Jerry.
- mattrx
I couldn’t remember if it was you or Wes that I handed it off to. Yes, it is/was this motor exactly. I’m glad it will finally get used!Jerry B. wrote:Hi Matt,
Thanks, Jerry
Matt
