Hi all,
I am restoring a Victor Victrola Motor
I degreased with petroleum all the gears that were stuck with hardened grease, I opened carefully the barrell with my pathologist's gloves and helmet and one of the two springs has broken.
Could you please help me finding a new one?
You can see the motor in the pictures.
I saw on ebay a lot of springs but I don'tknow what fits into my motor.
Thank you!!
WANTED: Victrola springs
- Lucius1958
Re: WANTED: Victrola springs
Ron Sitko is the one to call.
You should probably replace both springs at the same time, for best results.
- CDBPDX
This motor takes 2 - 1 ¼" wide, 18 ½ feet long Victrola springs with pear shaped holes at each end. The arbor diameter is ⅝".
As mentioned above, Ron Sitko is an excellent source for springs. He will know exactly what spring you need.
Have fun! Cliff
Have fun! Cliff
Exactly, I found them!! Thank you very much.
Unfortunately, when I removed the springs I did not note down their direction... I read on the forum that the wing near the main gear must be clockwise and the other one counter clockwise... can you confirm that?
Thank you.
Thank you.
