If you live in one of those areas where you will be hibernating from now until April....well, why not two wintertime projects?
For your consideration, here is a Victor III that needs some TLC. All that's missing is a crank, otherwise the machine is complete.
This machine has an aftermarket panel horn. The elbow has been glued or soldered to the horn???...don't know why. And the motor needs a tune-up. It might even need a spring replacement because I could not get it to run. But the motor is all there and complete. As you can see by the photos, it needs some clean-up and re-finish work. There are also some tight splits in the back wood panel that will need gluing. The reproducer that came with it is wrong, so I happen to have a correct Victor Exhibition reproducer that is in excellent condition It's included in the deal.
This is another cure for the wintertime blues. It's like getting a flu shot.
Asking $750 but offers accepted. Add for shipping in two boxes via Fed Ex Ground from Zip Code 94954.
Personal check or Paypal Friends and Family only.
Best...Mark
SOLD: Project No. 2 - Victor III - $750
