Edison ‘Fireside’ Model A w/Model K Combination 2/4-m reproducer. A bit of a project, but could be playing and looking good with just a little love. The motor is fine. Has crank. No belt. Pin-striping poor on bed plate. Finish on case is dry. Lid has some missing veneer near edges. Lower lid latches are missing. Both styli appear to be present. The hinge block screw that secures the weight is missing and someone has put a bent piece of wire through the hole as a substitute. No crane or horn. Lowish serial number of 1406.
Located in Jerome, Arizona near I-17/I-40 corridors. Will ship at buyer’s expense. Well-packed, the shipping box is 15.5”x15.5”x13.5” and weighs 19.12lbs. if you’d like to calculate shipping to your zip.
SOLD Pending Payment: Edison Fireside project $250
