Hello friends and neighbors,
I was looking for a nickel crank escutcheon. Hole diameter in the wood is ¾", screw hole to screw hole 1.25", and diameter of the crank shaft is ⅜ (But the hole is usually larger.)
It will help if you still have some mounting screws.
This is going on a Victor III, but with VTM's policy of using the best hardware and failing to replace it when said hardware went out of date, the right escutcheon should appear on Victrolas as well. Or maybe in the bottom of your parts bucket. In which case let me know.
Thanks!
WANTED: Victor / Victrola crank escutcheon
