FOUND: Columbia BZH Crank Needed
- pellicano1
Trying to find a female ended crank handle for my BZH phonograph. I measured and it appears to be 5/16" wide. Needs to be have at least a 4" shaft. The one I has a female opening of ¼" which is a tiny bit too small. Thanks!!
Thomas A. Edison
Thomas A. Edison
Re: WANTED: Columbia BZH Crank Needed
I might have the correct crank for this. It either used a crank with the slender handle, or the one with the bulbous shaped handle. Either one is correct. PM me if interested.
- pellicano1
I may have found one! As soon as I test it when it comes in I will let you know! Thanks!!Phonofreak wrote:I might have the correct crank for this. It either used a crank with the slender handle, or the one with the bulbous shaped handle. Either one is correct. PM me if interested.
Thomas A. Edison
Thomas A. Edison
