Not mine. A bit odd in that is has a non-standard grill similar to the extra cost "flattened urn" grill available for the C200, but this grill is certainly not flat!
https://www.facebook.com/marketplace/it ... 9482623236
Edison DD A200 oddity, Pennsylvania $100
Re: Edison DD A200 oddity, Pennsylvania $100
viewtopic.php?f=2&t=33058&p=196550&hilit=+a+200#p196550
Here's one I posted about a few years back. Steve
- fran604g
It's an attractive non-original addition, but it looks as if it doesn't quite fit - as the top is clearly not engaged properly with the cabinet.
That grille is an original option. Rarer than the plain one usually found on this model. I have owned one of each over the years.
Wes
Wes
- fran604g
I stand corrected, thank you. I learn something new every day, and that's one reason I love and respect this hobby and forum. Is the center medallion nickle plated metal? It's very attractive.downsouth wrote:That grille is an original option. Rarer than the plain one usually found on this model. I have owned one of each over the years.
Wes
Cheers,
Fran
Called the ‘flattened urn’ grille.
