Columbia 800, Turntable needed.
larryh
Post by larryh »
My 800 model Columbia Viva Tonal record players turn table was evidently drilled off center from the back side. The tapered opening on the rear is obviously more to one side than the other and it causes the records to move up and down noticeably especially on 12" records. I wonder if any of you who may have the 800 or 810 have some other Columbia Turntables and could check to se if there the same the way they fit on the spindle or if the larger machine had a different fitting all together??
Larry
