I am offering an Edison Fireside Model B with a cygnet horn. Serial No. 104016. The Model B is the 4 minute version of the Fireside. The photos will speak to the condition of this machine, but here's some important observations:
The Good:
- Original finish on the case and lid. Case is nice with tight joints and bedplate frame.
Original Edison script decal
Beautiful bedplate paint and the pinstriping is close to 100%
Original nickel plating with some wear on the mandrel
Strong motor and spring
Has the Diamond B reproducer in a horizontal carriage
Complete with crank and back bracket
Nice original black 10-panel horn....little paint loss and only a few dents. Presents well.
Original elbow
- Motor will require servicing, tuning, and lube
Reproducer will need to be rebuilt. The linkage is too long. Plus should check the diamond for wear.
There's two unexplained holes in the top of the reproducer. Have no idea as to why.
Mandrel wear as noted above...about 40% worn off.
The cygnet horn has it's original black paint, but someone in the past touched up or repainted the gold stripes on the ribs. Doesn't look bad, but it's not original
- The lid has a veneer chunk missing. Could be repaired with some effort. But lids are stored in closets anyways....right?
Lid also has a trim separation and the finish doesn't match the case very well...a little shade or color difference.
The crane is a reproduction.
I have taken lots of photos. PM me if you seriously interested and I'll get you more photos.
Asking $750 plus the cost of packaging and shipping via Fed Ex.
This will require two boxes. Machine will be carefully boxed and horn will have a special, custom-made box. Cost of shipping across the country (sea to sea) from 94954 will run between $150-175. Little less to the Midwest.
Personal check preferred payment on this one.
Mark
