Reproduction crank? Untouched. Original exhibition reproducer, original zinc bell horn, original horn support, original traveling arm, original oxide finish on the motor board, support arm, and corner protectors. Original feet, original horn elbow, original turntable felt, original brake and original speed screw. No record hold downs were used on this model. Clean, straight cut gears with minimal wear. Strong motor with plenty of torque, original and complete. The Phonograph runs smoothly and when fully wound it will make its way through a record without the need for rewinding. Clean original zinc bell Horn with original paint showing wear and things of age, almost 120 years old. Comes with one original 7 inch record.
I do not know why the pictures are loading sideways but tap on them and they straighten out!
Located in Greenville, South Carolina
Sold: Victor R. $900
- Personal Text: YouTube: Dyslexic Genius Hurt
Online
Re: For sale: Victor R. $900
Reproduction crank?
cheryla wrote: ↑Sun Dec 05, 2021 1:11 pm Untouched. Original exhibition reproducer, original zinc bell horn, original horn support, original traveling arm, original oxide finish on the motor board, support arm, and corner protectors. Original feet, original horn elbow, original turntable felt, original brake and original speed screw. Reproduction crank. No record hold downs were used on this model. Clean, straight cut gears with minimal wear. Strong motor with plenty of torque, original and complete. The Phonograph runs smoothly and when fully wound it will make its way through a record without the need for rewinding. Clean original zinc bell Horn with original paint showing wear and things of age, almost 120 years old. Comes with one original 7 inch record.
Online
Nice machine!
- Personal Text: When cycling, an overpass is not considered a mountain!
Pm sent
