Exhibition Reproducer Serial Numbers
phonojim
Re: Exhibition Reproducer Serial Numbers
Post by phonojim »
I have an early 1907 VTLA, s/n 3XXX. The gold Exhibition reproducer has a round hole needle chuck, round head adjustment screws with knurled locknuts and a serial number of 244837. From information given by the seller when I bought the machine, I have every reason to believe that the reproducer is original to the machine.
Jim
clevelander
Post by clevelander »
I have an HMV machine with an early HMV Exhibition soundbox with round hole for needles.
The label states that it was made 18/12/19 (OK rearange the first two numbers in the US) but it has no serial No that I can find.
Where are the numbers normally found?.
Henry
Post by Henry »
On mine, the numbers are stamped into the metal back plate near the perimeter.
Lucius1958
Post by Lucius1958 »
Victor E long throat, ca. 1902: #32589
clevelander
Henry wrote:On mine, the numbers are stamped into the metal back plate near the perimeter.
This reproducer would appear to not be numbered anywhere.
Under the diaphragm it states "His Master's Voice, Exhibition, Made in England"
I also have one which did not come with a machine so I do not know it's date.
It has a triangular needle hole, Serial No 9902 and reads "His Master's Voice, The Gramophone Co. Limited London-Berlin-Paris. Exhibition. Made in USA."
phonohound
Post by phonohound »
Hi;
I have a Victor Exhibition for a rigid-arm Victor E with a very low serial # of 1406.
alang
VTLA
Personal Text: TMF Moderator
Post by alang »
Exhibition with round needle hole S/N 174460 from my 1906 Victor II S/N 24850.
Starkton
Post by Starkton »
Thank you all for the valuable contributions! Please add more.
phonohound wrote: I have a Victor Exhibition for a rigid-arm Victor E with a very low serial # of 1406.
This is very low indeed. Is the distance of the mounting holes different from later specimen?
The following machines came out of private homes or through general antique dealers many years ago. I'm certain that the Exhibition sound boxes are original to the respective machines:
Victrola XVI No.76975 E (mine since 1967): Exhibition No.49084 B
Victrola XII No.2781 (early pre-1910 cabinet; mine since 1998): Exhibition No.324919
Victor I No.10825 (mine since 1972): Exhibition No.45168
Victor II No.41998 (mine since 1974): Exhibition No.193888
Victor III No.13406 A (mine since 2001; previous owner is non-collector and owned since 1970): Exhibition No.353743
There's an early VV IV here, but I honestly can't recall if I got it with its sound box, so I'll not volunteer any possible bad data. :)
phonohound
Hi Starkton;
Yes, the mounting holes are slightly closer and there is no rubber flange since the reproducer mounts directly to the tonearm piece that holds the reproducer.
