New Member of this forum from Denmark :)
Billehifi
Re: New Member of this forum from Denmark :)
Thanks Bruce
Yeah that could be nice
US PHONO
Really nice job restoring that little phonograph, congratulations & welcome to the Forum! You have some very nice machines.
tomb
Nice machines , it is great to welcome a collector who can add his knowledge to this forum. Tom B
Billehifi
Is it possible to fix this spring? and how?
Needs to be replaced, the steel fatigued. I recommend extreme care when removing it, the pieces have sharp edges and may eject with high energy. The best would be to push the spring parts with a screwdriver having the barrel inside a thick cloth sack.Billehifi wrote:Is it possible to fix this spring? and how?
- Marco Gilardetti
Ditto, absolutely impossible to repair, even in case it would immediately break in another point. Needs to be replaced.
Some say that this happens when a phono/gramo is left wounded up and then stored in a place with temperatures below zero.
- NEKTREG
Welcome Johan!
We now us from Facebook and Instagram I think?
I'am also new here in this Forum.
Greetings from Germany,Dario
Billehifi
Hello Dario
Welcome to this forum
Glad to see you in here
Kevan
- Personal Text: Over Hill And Dale.....and back again.
Welcome to the forum
You need to measure the length and width of the spring and take note of the type of ends you need to replace the spring. Make SURE you mark the direction of the spring with a marker on tape so the new spring is installed the same direction.
Kevan
Kevan
Billehifi
Hello again
I've bought this HMV gramophone and got it very cheap. It was standing inside a red cross shop in Copenhagen and I got it for about 45 dollars(VERY Cheap)
The spring is broken and the soundbox is missing. The tonearm needs a small screw(but I think, I have one in spare parts)
What do you guys think of my buy?
