HMV 101 - Please help diagnose the problem
Phono48
Re: HMV 101 - Please help diagnose the problem
Post by Phono48 »
Orchorsol wrote:As Teak says, it's for a tin of HMV Tungstyle semi-permanent needles (called Tungstone in the US) - the tin is longer, slimmer and narrower than the usual tin shape.
But don't spend a lot of cash buying a Tungstyle needle tin, that clip is vicious, and will remove the design on the tin the first time you push it in!
Post by OrthoFan »
In case you don't have one, here's a PDF version of the original owner's manual --
HMV101 - Instruction leaflet - 2014D.pdf
(3.11 MiB) Downloaded 386 times
which is also downloadable from here -- http://badonoer.blogspot.com/2015/01/in ... bling.html
HTH,
poodling around
Post by poodling around »
Thank you for this practical advice.
poodling around
OrthoFan wrote:In case you don't have one, here's a PDF version of the original owner's manual --
HTH,
Very good ! Thank you for the link. Most interesting indeed.
