Edison Triumph Model A restoration
- Le0
- Personal Text: avid 22 years old collector
Re: Edison Triumph Model A restoration
I saved the pictures from the Ebay ad:
Machines I own: Edison Standard A, suitcase Home, Home A, Triumph A & B, Columbia type BS, Standard Model A, Victor E, IV & V, Pathéphone No.4
Schlick
wtt11- Good thought! But the holes & marks seem the same on both sides.wtt11 wrote:an electric winding up motor??
Leo- thanks for the 'before' pictures!
- NEFaurora
Yes, For screws... Use Birchwood and Casey Gun Blue. You can buy it at Wal-Mart in the Sports Section..
Tony K.
Edison Collector
Tony K.
Edison Collector
Schlick
In the middle of giving my Triumph a bath (GoJo), a spring fell out of the what-I-thought-was-empty case.
Any ideas where it might go on this machine (or do you think it was a stow-away?
(Some one changed the case color so now it is kind of part red oak and part green oak. [The case, not the spring.] Didn't make the spots where someone installed handles any less obvious, either!)
- Chuck
My offhand guess is it's maybe a belt tensioner spring.
That is just a wild guess though.
By the way does your machine mistrack when playing both
2 and 4 minute records?
-Bell System Credo
-Bell System Credo
martinola
I suspect it was our friend, Mr. Sun.Schlick wrote: (Some one changed the case color so now it is kind of part red oak and part green oak. [The case, not the spring.] Didn't make the spots where someone installed handles any less obvious, either!)
- Martin
That spring doesn't belong with the Triumph. It's a stowaway.Schlick wrote:Oops!
Triumphs don't use use spring-loaded idler wheels. The motor itself can be raised and lowered slightly via an adjustment screw, and this adjusts the belt tension.
- Andersun
That spring is the same style as on cygnet horn crane other than it is a bit heavy duty like for a trampoline!
Schlick
Yes, it skips on both 2 min &4min. (Ha! You found out I only have one machine to post about under every topic too!)Chuck wrote:By the way does your machine mistrack when playing both
- Le0
I'd suggest making a new thread with all the questions related to your machine...
