Well, I talked to the people that I got the records from. The records were from the "attic". So it may have to go down as an unsolved mystery.
Tim
Odd OKEH Records
- Wolfe
Re: Odd OKEH Records
Could be a distant relative was a record industry guy. Maybe a mover and a shaker at Okeh records in the 1920's. "Attic finds" like that in the 21st century are very lucky.
- AudioFeline
- Personal Text: Sounds good to me...
I don't think test pressings would require writing on them. They might press the record then evaluate it immediately and make adjustments, in which case they would know exactly what the record is and wouldn't need to write because it was intended for temporary use only.
Some test pressings might be made for management, artist, marketing or other approval, in which case it makes sense that the details will be written on the disk because it will be passed onto external hands.
- Wolfe
Adjustment ? This was before the days when they could evaluate a cutting and then go back and "fix something in the mix" or the mastering.
