I am going to try repairing a bunch of my cylinders. I would like a reamer. Used is fine, crappy is fine. It just needs to ReAm!
Thanks!
Kirk
WANTED: Cylinder reamer
- OldRestorer
It's not what you say... It's what you do...
Stephen_Madara
- Personal Text: www.glassphonohorns.com
Re: Want to buy: Cylinder reamer and Mandrel
I have an unused old oak reamer that needs sandpaper strips attached and an amberola mandrel I could let you have the pair for 40.00 plus actual shipping if you are interested.
- OldRestorer
I am going to need a shaft on the mandrel. Are there threads in the end that I can use a rod in? I see some online with shafts.
Thanks
Kirk
Thanks
Kirk
- Lucius1958
If it's from a 30/50/75, at least, it would have been held on the shaft by a collar with a set screw.OldRestorer wrote:I am going to need a shaft on the mandrel. Are there threads in the end that I can use a rod in? I see some online with shafts.
Thanks
Kirk
Herman
Have you found what you needed? I have a mandrel from a 2min only Home. Perfect for what you want as it has a very beefy shaft. No reamer though.OldRestorer wrote:I am going to need a shaft on the mandrel. Are there threads in the end that I can use a rod in? I see some online with shafts.
Thanks
Kirk
Herman
- OldRestorer
Re: Want to buy: Cylinder reamer and Mandrel W shaft
Hello,
I was offered the above but I need a shaft on it.
It should look like this photo below.
I need a good shaft for stability when trying to reform these cylinders. If it even works..
Kirk
Kirk
- Screen Shot 2018-04-29 at 2.47.14 PM.png (143.81 KiB) Viewed 3776 times
Herman
The most rigid shaft you will find attached to a mandrel is from the 2min Home as I mentioned in my post. Here is a picture sample I borrowed from a previous post from Victroladoctor. Hope he does not mind. The one I have is in my attic and too hot and lazy right now to bring it down to take pictures. The feedscrew threads on my mandrel are no good so no use on a phonograph but will suit your needs.
$25.00 includes shipping if you are interested.
- mandrel (1).JPG (110.66 KiB) Viewed 3772 times
- OldRestorer
Looks good!
I will take it and will message you.
Kirk
Kirk
- OldRestorer
Mandrel found!
Stephen_Madara,
Can you sell me just the reamer?
Thanks,
Kirk
Stephen_Madara,
Thanks,
Kirk
- OldRestorer
Re: WANTED: Cylinder reamer
I have not heard back so I am STILL looking for a reamer.
Thanks,
Kirk
Thanks,
Kirk
