Victor O advice needed.
- Phono-Phan
I recently bought this Victor O. It has many issues. The tone arm is incorrect, the tone arm cradle is home-made, the crank is home-made, the case is a bit rough, the round hole Exhibition reproducer is incorrect and has a badly damaged needle bar, and the horn needs no explanation. On a plus side, the horn elbow is very nice, the back bracket is nice, it has the correct cast turntable, brake, and strong motor. I have always been disappointed to see machines get dismantled and sold for parts. But, I believe this one is beyond an economical repair. What do you all think?
- DSCN1804.JPG (129.76 KiB) Viewed 1844 times
- DSCN1805.JPG (114.26 KiB) Viewed 1844 times
- DSCN1806.JPG (112.83 KiB) Viewed 1844 times
Re: Victor O advice needed.
I'd say, fix it. There's enough there to work with (Including a nice bit of provenance!)
It's really a neat phonograph.
Does the tonearm work properly and with an Exhibition come close to the spindle? Jerry
- Phono-Phan
The tone arm is a mess. There are extra holes in the back and a home made wire bale for it to pivot on. I will post pictures when I can later.
- Phono-Phan
Here a pictures of the tone arm. The home made tone arm cradle broke when I tried to remove the tone arm. Maybe if I can find a replacement tone arm, this one is worth restoring. I know these models were made for many years with variations. The O in my collection has a different tone arm support pivot. Does anyone know if the tone arms are the same throughout production?
- DSCN1811.JPG (109.33 KiB) Viewed 1668 times
- DSCN1810.JPG (102.63 KiB) Viewed 1668 times
- DSCN1809.JPG (91.92 KiB) Viewed 1668 times
- DSCN1807.JPG (115.01 KiB) Viewed 1668 times
jhon
- Personal Text: Victor Machine guy
I just recently purchased a Victor O. The tonearm does not have the goose-neck and the soundbox is mounted directly to the tonearm. It has a pivot, but does not stay in the elbow to the horn. Was this normal? It has a serial number of 6000 something, so I'd say it was an early version. The motor has issues, but I can deal with them.
I believe the tone arm is correct. There should be a small spring that loads into the small hole in the back bracket. The pin that is part of the pivot in the tone arm joins with the back bracket. The pin rests on the spring and provides enough vertical lift so the tone arm almost mates with the back bracket. I bet all you need is the little spring.
Ideally with most any talking machine you'd like as airtight a connection between the tone arm and the horn as possible. The connection with this type of Victor O is much less than ideal but it's a budget machine so compromises were made. Also, it's such a cute machine that the shortcomings are easy to overlook. This is the same machine as presented at the top of this thread.
Jerry Blais
Jerry Blais
- Phono-Phan
You did a great job on bringing the Victor O back to life. Did you keep the note of it surviving a fire with it when you sold it?
Ken Brekke
Ken Brekke
Yes, I kept the Leutys slip of paper inside the cabinet along with an "as found" photo. I love a great project.
