Good Evening All,
I have found myself in a bit of a pickle. I own an Edison Fireside Model A and I am looking to make use of a Model N reproducer.
I require the larger carriage arm that the reproducer sits within, however, I have no idea what style carriage arm is compatible with my Fireside Model A.
Will a large standard carriage arm do the trick or is a fireside model b (larger style) the only compatible option on a Fireside model A
Edison Model N Reproducer
Re: Edison Model N Reproducer
The Fireside horizontal carriage is specific to this model and the Amberola X, so you need to find one of those for this to work. You might try George Vollema - Great Lakes Antique Phonograph... https://www.victroladoctor.com/
You could also place a "WANTED" in the Yankee Trader section or Machines on this forum.
Phonosteve
Thanks Curt,
I will be on the lookout for these two now.
Really appreciate the advice
