Manage Drafts
oliver
Personal Text: always in the mood for a new basket case phonograph
Manage Drafts
Post by oliver »
Hello all,
Could someone please tell me how to post a saved draft?
Thank you,
Oliver
52089
Re: Manage Drafts
Post by 52089 »
Go to your User Control Panel and click on Manage Drafts. This will bring up a list of the draft posts you have saved. Click the appropriate post and edit as needed. You should have the usual Submit button available.
oliver
Re: Manage Drafts
Post by oliver »
To this day, I still don't understand how to send a PM that is sitting in Outbox. While I'm following the directions outlined above, there is no "Send" or "Submit" button. Thank you.
gramophone-georg
Re: Manage Drafts
Post by gramophone-georg »
oliver wrote: Sat Apr 20, 2024 9:56 pm To this day, I still don't understand how to send a PM that is sitting in Outbox. While I'm following the directions outlined above, there is no "Send" or "Submit" button. Thank you.
If it's sitting in your outbox, that means you DID send it, but, for whatever reason, your recipient never opened it. Copy, paste, and resend.
Re: Manage Drafts
Once you are in the Manage Draft, and you see the draft messages in the list, each one has two links below, LOAD DRAFT and VIEW/EDIT:
If you enter by VIEW/EDIT, you can modify our clean your draft, but not send it:
And if you enter by LOAD DRAFT, you can edit your draft, SAVE, PREVIEW or directly SUBMIT it:
It is a bit tricky...
oliver
Re: Manage Drafts
Post by oliver »
Thank you for the detailed explanations. That was most helpful.
Re: Manage Drafts
Lessons learned after frustrating trials...
oliver
Re: Manage Drafts
Post by oliver »
At the risk of sounding like a total imbecile , I am still struggling with the messaging system. What does it mean when you write someone a PM, hit "Submit", and 24 hours later the PM doesn't appear in your "Outbox" or "Sent messages"? IMO, that means the PM didn't go through, right?
I always get the following after trying to post, or send a PM:
This page isn’t workingforum.talkingmachine.info is currently unable to handle this request.
HTTP ERROR 500
Thank you.
