I could not find a good reference to see when my vic 1 was made. Any quick references?
serial number 44708
And excuse my ignorance... But did most of them come with eight or ten inch platters? This one has an eight.
Vic 1
Re: Vic 1
The early Victor I had an 8" turntable. Is this the small cased one? I'm sure it has a bullet brake. I think your machine came out around 1906-1908. The early larger case one had an 8" turntable, also. In 1909-1910, Victor came out with the 10" pressed steel turntable.
ts_13 wrote:I could not find a good reference to see when my vic 1 was made. Any quick references?
serial number 44708
- AZ*
Re: Vic 1
A good reference for this type of inquiry is the Victor Data Book. It is available here:
http://mulhollandpress.com/styled-5/sty ... index.html
Best regards ... AZ*
Re: Vic 1
My great grandfather had that model and for a while I did as well, another member here probably still has it. It was dated under the turntable as 1904. It had an 8 inch table and usually wouldn't make it though a whole side of that.
Larry
Larry
Re: Vic 1
You are exactly right! This one has a really small case, with bullet brake. I love how small it is.Phonofreak wrote:The early Victor I had an 8" turntable. Is this the small cased one? I'm sure it has a bullet brake. I think your machine came out around 1906-1908. The early larger case one had an 8" turntable, also. In 1909-1910, Victor came out with the 10" pressed steel turntable.
Harvey Kravitzts_13 wrote:I could not find a good reference to see when my vic 1 was made. Any quick references?
serial number 44708
