WANTED: Cylinder reamer
earbleeder
Re: WANTED: Cylinder reamer
Post by earbleeder »
I think I got mine from somebody named Bountiful antiques on eBay the other one listed on eBay was the wrong taper. So be careful check on a junk record first. It was well worth the 40 something dollars on one strip of sandpaper that came with it I did over 500 records easily and you can replace the Sandpaper with some from Menards for a couple bucks
fmblizz
Post by fmblizz »
probably a dumb question but why do you need a mandrel and shaft??
just ream it and test on a machine...
what am I missing??
blizz
Herman
Post by Herman »
fmblizz wrote:probably a dumb question but why do you need a mandrel and shaft??
what am I missing??
blizz
I believe he is using it as a form to repair plaster from damaged cylinders. Waiting to hear his progress.
OldRestorer
Post by OldRestorer »
Missing?
I need a reamer. I roll dough with it.. ;)
Thanks for the heads up on the eBay ones. I don't want to throw $45.00 for the reamer and $12.00 for the sanding strips into this little project.
I am reforming the actual cylinder composite plastic. Then I will refill the plaster and groove it.
Kirk
It's not what you say... It's what you do...
Herman
Post by Herman »
OldRestorer wrote:Missing?
Kirk
Kirk, Bear in mind that the celluloid collapses in the area that there is plaster loss. You will end up with flat spots unless you have a method of applying pressure to expand the plaster. That is based on partial plaster loss repairs. For full plaster replacement you will most likely end up with reduced diameter of the cylinder overall.
Just my 2 cents input.
Good luck
Herman
OldRestorer
Yessir,
It will be a learning experience..
If I ever get a Reamer, :lol:
OldRestorer
Bump
Serial bumping here!
Last bumped by OldRestorer on Tue Oct 30, 2018 12:26 pm.
