For Bamboo, you can get cheap large bamboo canes in gardening stores, but you'll need one that is old and dry enough. I found mine in the trash bin!
In my opinion, the outer shiny hard shell or skin is not absolutely necessary. It is harder, yes, but I've also had good results with needles cut from other parts of the bamboo. If the fibres are hard, straight, tight, parallel and strong, better if they're old and dry, you can have good results anyway. And besides this, sometimes the shiny outer skin also has its own problems... Depends strongly on the type of bamboo you're using... Highly random until you learn by trial and error to identify the bamboo that will make good needles.
I don't use any treatment except let them needles dry, once cut out, by spreading them on a metal tray placed on top of the heater, then store them in a dry box or pot, with one of those moisture absorber granules bags.
