FOLLOW THE RESTORATION: 1890's "whisker" Edison Home Lid
MicaMonster
Personal Text: Never Settled
Post by MicaMonster »
I will preface this thread by saying that I am a sucker for an early Edison Home. Surely many of you have followed me through the skeletal Home renovation, and other ambitious restorations, but this one is a project that I not only SHELVED, but stared at in passing, contemplating if it could be done, and how the results would look.
The Edison Home, to me, is a beautifully styled and executed 1890's machine. Its shape, its badging....everything about it is just fascinating to me. The subtle design changes from year to year, all in the name of improving what started out as an underpowered and fragile machine. So, this lid came into my life.
It has TWO features which I just can't pass by. The earlier decals were mounted higher on the lid, in a location where the lid handle would unfortunately make contact with them, and the decals had slight differences. I consider them more elegant. The biggest difference is the cross hashing in the shaded areas of the banner. The earliest decals had "whiskers," clearly defined. The majority of surviving examples have very fine lined shaded areas. Here is a comparison.
EARLY:
LATER:
Not only does this lid have the early whiskers, but just to the right of center above the banner, there is printed (in reverse) "P.110".
Well. I finally decided to do something about this lid. And here is why. It has damage......damage very close to the original decal, and also on a curved surface. My FAVOURITE KIND OF REPAIR. (do you sense the sarcasm?)
Here's what I'm up against:
The lid is filthy. I had to clean the decal to see how savable it was, and to also get an idea of the wood grain I was working with. So, some spot cleaning was in order.
I will start by gluing in stages. Starting with the end panel, getting everything supported, then re-bonding the layers of extant wood until it is solid and stable, before filling in the 3 layers of wood: the underside veneer, the center "junk wood" layer (maybe made of walnut veneer) and then the top layer of finished veneer. Here is my donor lid (top).
Welcome to the restoration. I hope to post updates as work progresses. Hopefully, it turns out ok. When making spot repairs like this, I often worry about the wood grain contrasting too much.
Taming Orthophonics Daily!
Le0
Personal Text: avid 22 years old collector
Re: FOLLOW THE RESTORATION: 1890's "whisker" Edison Home Lid
Post by Le0 »
what ever it looks like when you're done will be much better than what it is now...
I can't wait to see how you'll fix this. :D
Machines I own: Edison Standard A, suitcase Home, Home A, Triumph A & B, Columbia type BS, Standard Model A, Victor E, IV & V, Pathéphone No.4
Dittoes on wanting to see your solution and progress...
Andreas Gramophones
Post by Andreas Gramophones »
I was impressed with the cleanliness that made part of the cover to see the tone of the wood, which used to take the crust of dirt?
Post by Phonofreak »
Thank you for posting this little known detail. I checked my early Edison Suitcase Home, and mine has that whisker decal that sat high on the lid. It's these little, obscure details that make these machines exciting. Keep us posted on your progress.
Wyatt,
What did you use to clean that area on the cover that looks so nice...?
MicaMonster
Harvey: Early lids with the whiskers and high decals are something that make my temperature rise and heart race. Again, once bitten by the banner lid Home, one is unlikely to find a cure.
Curt: I use a product called NEW LIFE FURNITURE MASQUE. It is GENTLE, and does not dissolve decals like Gojo or Kotton Klenser. It is VERY GENTLE, and buffered with orange oil. It takes dirt off slowly, and gives you more control in how you want to clean an item. It is made by RAMAX, and can be found on the internet. Best product I have ever used to clean wood.
SO! Work continues! I have sanded back the top veneer, to allow a bevel so I can feather in the new (old) veneer from my donor lid. Shown here, I am clamping the new pieces into position, and cutting back the excess.
Shown with additional donor veneer pieces. I have to build up the front a little with some veneer before selecting a grain that closely matches the original veneer. Then.....sanding.....filling......coloring. (oh....FUN!)
Good news is, projects like this require a little time investment every day, over many days, simply due to the fact that you are waiting for glue to dry.
MicaMonster
The first layer of veneer. Matching the pre-"bent" pieces from the donor lid. One area needs to be filled yet:
New piece bonded in place. The only thing that "bothers" me is that the pressure from the wood clamp left a slight flat spot above the decal. I don't want to put more wood there, because I would be creating more lateral hairlines. I might just leave it as it is. Might not even be noticeable with finish on it....
NEXT: take clips and handle off, and thoroughly clean the rest of the lid, and get it ready for some color dye and finish!!!
THEN: touch up the decal (hooray!)
Post by Jerry B. »
Looks like it is coming along very nicely. Jerry
gemering
Post by gemering »
The Wizard of Lake Placid strikes again!
