A and B 250 Database Project
fran604g
Post by fran604g »
Hi folks,
Because of my study of the Chippendale C 250, and it's sister the C 19, I've found myself needing to learn more about the earlier A and B 250 models. Therefore, I've found the necessity to begin a questionnaire on them to document the same basic information that I am currently also compiling on the Chippendale.
The Talking Machine Forum is only one source that I will be using, and as with the C250/C19 database project, I will record the data on a spreadsheet and eventually share my work with the historical/collecting community at large.
If you own an Edison Diamond Disc Phonograph model A or B 250, I encourage you to take the time to help me compile a useful database of information to be used as an eventual reference for those wishing to learn about them, and to be used as a guide for assessment and/or restoration.
Using images from the forum, and from the internet, and with guidance from members “Valecnik” and “phonogfp”, I have compiled this list of specific features that appear to have changed over the few short years that the A and B 250's were produced.
I realize this is a somewhat exhaustive study, and that some may not be able to answer all of the questions, but I hope many of you will do the best that you can and answer the questions as accurately as possible.
Thank you all for your participation! :)
1) Model designation on the data plate? "A250" or "B250".
2) What is the serial number on the dataplate? "SM - ??????"
3) What is the number stamped into the top of the motor-plate beneath the turntable? Example: 6969-A1 (Location shown in pictures below)
4) While you have the turntable removed, how many oil “ports” are present on the top of the motor-plate?
5) Looking at the underside of the motor-plate (if you are able to) how many oil “tubes” are present?
6) What is the “Date” on the paper label stuck to the inside of the cabinet rear inspection door?
7) What is the stamped number on the “1st Horn Joint” located directly below the motor mechanism?
8) What is the stamped number on the “2nd Horn Joint” just before the horn flairs out? (This one may be difficult to locate without disassembly, so please don't go out of your way for this one).
9) Is there a number conspicuously stamped into the cabinet on the bottom of the horn compartment? If there is; what is the number, and is it in the “Front” or “Rear” of the horn compartment?
10) What color is the motor-plate finish? “Reddish-Maroon”, “Chocolate-Brown” or “Black”. (Shown in pictures below)
10a) Is there a "Tone control or Mute Ball" present, "Yes or No"; if yes, then which type? "Reproducer with Felt Damper", "Pull Knob and Cable", "Pivoting Lever and Cable", or "Slider Control and Cable"
11) What color is the pin striping on the perimeter of the motor-plate? “Gold” or “Gold and Blue”.
11a) Is there decorative pin striping applied to the corners of the motor-plate? “Yes” or “No”.
12) Is the operating lever (lowers the reproducer for play) mounted to the “Cabinet” or is it mounted through the “Motor-plate” (Shown in pictures below)
13) Which type of start/stop lever configuration does your unit have? “Type 1”, “Type 2”, or “Type 3”? (Shown in pictures below)
14) What is the cabinet wood type? "Mahogany", or "Oak".
15) Are there “Tone Slots” cut into in the sides of the cabinet? “Yes” or “No”.
16) Is the horn painted in “Mahogany Wood Grain”, “Oak Wood Grain”, or “Black”?
17) What type of record storage system does yours have; “17-A”, “17-B”, “17-C”, “17-D”, “17-E, 17-F”? (See images below)
18) Is there an “Official Laboratory Medallion” mounted to the turntable trim piece? If there is, please describe it in detail.
19) Is there “grille cloth” present? If there is; what color is it, and please provide a brief description of the material.
20) Are there any dealer tag(s) or decal(s) present? If “Yes”, then please submit name, address, etc. and the location it is found on the cabinet.
21) What is the "Cabinet Factory No." (if any)? This can usually be found on a sticker inside of the horn compartment of the cabinet. Please provide the “Form No.” and any other notable numbers if present.
22) Does your cabinet have a conspicuous “Lip” around the inside top perimeter of your turntable compartment? “Lip” or “No Lip”.
23) How tall is your Phonograph, measuring from the bottom of the right front foot up along the cabinet corner frame piece (do not include the caster if one is present, please) turntable compartment corner? (As shown “Image 1” and “Image 2” below)
24) Are there any sales receipts, shipping documentation, etc., original to the phonograph? Dated and serialized materials are particularly noteworthy.
Special thanks to “dustie89”, “CDBPDX” and “Valecnik”, (and any others I may have forgotten) for some of the following images I pirated off of the forum, and George F. Paul for his B 250 images.
Best,
Fran
Re: A and B 250 Database Project
Fran, I'm happy to provide you with this information, and I look forward to learning more about Edison Disc Phonographs.
1) Model designation on the data plate? "B250".
2) What is the serial number on the dataplate? "SM - 3424"
3) What is the number stamped into the top of the motor-plate beneath the turntable? None.
4) While you have the turntable removed, how many oil “ports” are present on the top of the motor-plate? 2 plus spindle.
5) Looking at the underside of the motor-plate (if you are able to) how many oil “tubes” are present? 4+4.
6) What is the “Date” on the paper label stuck to the inside of the cabinet rear inspection door? No label on door. An undated Form 632 is glued just behind the grille on the left interior side.
7) What is the stamped number on the “1st Horn Joint” located directly below the motor mechanism? None.
8) What is the stamped number on the “2nd Horn Joint” just before the horn flairs out? None.
9) Is there a number conspicuously stamped into the cabinet on the bottom of the horn compartment? No.
10) What color is the motor-plate finish? “Reddish-Maroon.”
11) What color is the pin striping on the perimeter of the motor-plate? “Gold” with no corner decorations.
12) Is the operating lever (lowers the reproducer for play) mounted to the “Cabinet” or is it mounted through the “Motor-plate” Motor plate.
13) Which type of start/stop lever configuration does your unit have? “Type 3.”
14) What is the cabinet wood type? Mahogany.
15) Are there “Tone Slots” cut into in the sides of the cabinet? No.
16) Is the horn painted in “Mahogany Wood Grain”, “Oak Wood Grain”, or “Black”? Black.
17) What type of record storage system does yours have; “17-D.”
18) Is there an “Official Laboratory Medallion” mounted to the turntable trim piece? No.
19) Is there “grille cloth” present? If there is; what color is it, and please provide a brief description of the material. Yes, as shown in the first measurement image. Pumpkin color with a satin-like texture. Original to a C-150, but perfectly matches the remnants still present on the grille.
20) Are there any dealer tag(s) or decal(s) present? No.
21) What is the "Cabinet Factory No." (if any)? Cabinet Factory No.2. Form 890. There is also a small penciled "3/15."
22) Does your cabinet have a conspicuous “Lip” around the inside top perimeter of your turntable compartment? “No Lip”.
23) How tall is your Phonograph, measuring from the bottom of the right front foot up along the cabinet corner frame piece (do not include the caster if one is present, please) turntable compartment corner? 44.5"
24) Are there any sales receipts, shipping documentation, etc., original to the phonograph? No.
Good luck with this worthy research, Fran! :)
fran604g
Post by fran604g »
Thank you, George, I'll add your B250 to the database. :)
fran604g
Post by fran604g »
Hi folks,
I amended the survey to include the following feature:
Best,
Fran
10b) Is there a "Tone control or Mute Ball" present, "Yes or No"; if yes, then which type? "Reproducer with Felt Damper", "Pull Knob and Cable", "Pivoting Lever and Cable", or "Slider Control and Cable". Yes - Slider Control & Cable.
FloridaClay
Post by FloridaClay »
1) Model designation on the data plate? A250
2) What is the serial number on the dataplate? SM - 8355
3) What is the number stamped into the top of the motor-plate beneath the turntable? 8355-A1
5) Looking at the underside of the motor-plate (if you are able to) how many oil “tubes” are present? 4+1. (It is possible that there could be more from the right hand port, but I was only able to see 1.)
6) What is the “Date” on the paper label stuck to the inside of the cabinet rear inspection door? Label is present, but in poor condition and date, if there was one, is now missing.
8) What is the stamped number on the “2nd Horn Joint” just before the horn flairs out? 2545
9) Is there a number conspicuously stamped into the cabinet on the bottom of the horn compartment? Yes there is a number, 2308, but it is stamped into the top of the bottom cross-member of the frame the rear inspection door closes into, at the bottom and visible only when the inspection door is open.
10) What color is the motor-plate finish? “Black.” Original with matching numbers, but I understand black is fairly rare for an A250.
10b) Is there a "Tone control or Mute Ball" present, "Yes or No"; if yes, then which type? "Reproducer with Felt Damper", "Pull Knob and Cable", "Pivoting Lever and Cable", or "Slider Control and Cable” Pivoting Lever and Cable
11) What color is the pin striping on the perimeter of the motor-plate? Gold with corner decorations.
12) Is the operating lever (lowers the reproducer for play) mounted to the “Cabinet” or is it mounted through the “Motor-plate” Cabinet
13) Which type of start/stop lever configuration does your unit have? Type 1
16) Is the horn painted in “Mahogany Wood Grain”, “Oak Wood Grain”, or “Black”? Mahogany Wood Grain.
17) What type of record storage system does yours have; 17-A
19) Is there “grille cloth” present? If there is; what color is it, and please provide a brief description of the material. Yes, green silk, but it is not original.
21) What is the "Cabinet Factory No." (if any)? None that I can find.
22) Does your cabinet have a conspicuous “Lip” around the inside top perimeter of your turntable compartment? Yes
23) How tall is your Phonograph, measuring from the bottom of the right front foot up along the cabinet corner frame piece (do not include the caster if one is present, please) turntable compartment corner? 44.25"
Clay
fran604g
Post by fran604g »
Wonderful, Clay, thank you!
Fran
fran604g
Post by fran604g »
Hi folks,
Changed part "10b" to read "10a" :oops:
Fran
Valecnik
Post by Valecnik »
fran604g wrote:Hi folks,
Fran
Fran I'll get you my info soon. I'm totally knocked out with Lyme disease of all things. Ticks me off! Now back to sleep....
fran604g
Post by fran604g »
Fran
Thanks Bruce, no hurry. :)
Lyme disease, geez, I hope it can be resolved, I've heard horror stories... :(
Fran
