ID plate
rvwenger
ID plate
Post by rvwenger »
Where do you get the replacement nails for the Victrola ID plate? Also, any tips on restoring. Has there been a post covering this for the later non brass plates.
Re: ID plate
Post by Phonofreak »
I use small escutcheon nails you can get at a good hardware store. They are available in nickel, copper, or gold color. They are pretty close to the original and come in different sizes.
rvwenger
Re: ID plate
Post by rvwenger »
Phonofreak wrote:I use small escutcheon nails you can get at a good hardware store. They are available in nickel, copper, or gold color. They are pretty close to the original and come in different sizes.
Thanks !
rvwenger
Re: ID plate
Post by rvwenger »
The tag I want to restore.
Re: ID plate
My personal view, for what that's worth, would be to leave it as-is. It's old and that's just part of its character and history. Not criticizing your intentions, just pointing out another take on it. Happy collecting!
rvwenger
Re: ID plate
Post by rvwenger »
JerryVan wrote:My personal view, for what that's worth, would be to leave it as-is. It's old and that's just part of its character and history. Not criticizing your intentions, just pointing out another take on it. Happy collecting!
Thanks Jerry. Your probably saving me a bunch of work :D The rest of the VV-X looks great after it's cleanup, this will show what it came from. :)
rvwenger
Re: ID plate
Post by rvwenger »
The before
rvwenger
Re: ID plate
Post by rvwenger »
the before
rvwenger
Re: ID plate
Post by rvwenger »
Afterwords.
estott
Re: ID plate
Post by estott »
Restoring those plates is a tricky procedure. First the place needs to be polished and replated. They you enamel the whole thing black, and THEN you buff / scrape / polish/ the black off of the raised areas....and the plate has to be perfectly flat to get a proper result.
