Faultless feet ??
jmreynol
Faultless feet ??
Post by jmreynol »
I have an Edison S19 diamond disc player that I am restoring and I have run into a problem that I was hoping someone could help me with.
The machine was in pretty rough shape, especially the casters (brand name: Faultless Feet) which look to have been gold plated. I could re-plate them but I have decided to guild them to match the caps. But, they were in such bad shape I had to take them apart. In doing so I found that that shaft that the wheel spins on was wound in cotton string. I am assuming this was done for a better fit and to hold lubricant. My problem is: How do I rewind the shaft or is there some other substitute fix that people use?
Re: Faultless feet ??
You may be in virgin territory with this, since I don't think most people disassemble their casters... but what do I know?
That being said, if I were going to attempt to rewind string around a shaft, I would put the shaft in a drill chuck and secure one end of the thread/string with glue. Then I would turn the chuck by hand and wind the thread onto the shaft... Before cutting the thread, I would secure the end of the thread with glue and once hardened cut it off...
Just a thought... never done this and no guarantees...
Otherwise, replace the existing shaft with a larger size if it is too sloppy... a cut off nail or other metal rod material should work...
I would replace the string with nylon or teflon tubing, slid over the pins. I find it hard to believe it was wrapped with cotton string, but I don't doubt your findings.
